jj2523
Apr 26, 2019Aspirant
Add Drive to RN 102
I have a RN 102, with one 4TB drive. The Volume screen says both 'Type: JBOD' [left side] & 'RAID (RAID 1)' [under the drive image]. I assume I'm in mode 'Flex-Raid' as I get a message 'You are atem...
- Apr 26, 2019
Hi jj2523,
Adding a disk for your protection on your JBOD volume converts it to RAID 1. That additional disk provides redundancy so if one of the disks dies, your data is still intact.
You may refer to the table on page 38 of the software manual for reference as well.
(Note: RAID is not enough to keep your data safe. You should also have other backup plans to keep them safe.)
JohnCM_S
Apr 26, 2019NETGEAR Employee Retired
Hi jj2523,
Welcome to the Community!
May I know the current firmware of the NAS? You should be able to add the 2nd 4TB disk and use it as RAID 1 with the existing disk by using 'Add Parity' option under the Volume Settings. You may check this link for more information regarding this.
jj2523
Sorry Version 6.10.0
