jj2523
Apr 26, 2019Aspirant
Add Drive to RN 102
I have a RN 102, with one 4TB drive. The Volume screen says both 'Type: JBOD' [left side] & 'RAID (RAID 1)' [under the drive image]. I assume I'm in mode 'Flex-Raid' as I get a message 'You are atem...
- Apr 26, 2019
Hi jj2523,
Adding a disk for your protection on your JBOD volume converts it to RAID 1. That additional disk provides redundancy so if one of the disks dies, your data is still intact.
You may refer to the table on page 38 of the software manual for reference as well.
(Note: RAID is not enough to keep your data safe. You should also have other backup plans to keep them safe.)
jj2523
Does not adding Parity just give me one bit protection, I was looking for the 2nd disk to be a full copy so that should either disk die I still have a copy. Or am i misunderstanding 'Add Parity'
JohnCM_S
Apr 26, 2019NETGEAR Employee Retired
Hi jj2523,
- jj2523Apr 26, 2019Aspirant
Thanks thats the explicit bit of information I was looking for. Your last sentance could be usefully added to page 38 - it explains what is happening - a non specialist wont read between the lines - thanks again
