super_poussin
May 08, 2013Virtuoso
Addons available For R6
Hello Guys, A quick list with port used by application Application Port 1 Port 2 Port 3 mysql 3306 subsonic 4040 4041 shellinabox 4200 istat 5109 phpmywadmin 7082 ajaxplorer 7084 ...
olest
Sep 04, 2013Guide
If you use L2TP you have to forward port 500 UDP and 4500 UDP to the NAS.
Access to the NAS it self is a limitation in the VPN server software I found but you can get it working anyway if you in the Local bridge setup add a TAP interface and in the Virtual hub enable secure NAT. You then have to access the NAS at the TAP interface.
