super_poussin
Apr 04, 2013Virtuoso
Addons on R6
Hello
Because it was disclosed most of you can installl addons without going on Genie, perhaps because you have R6 on old X86 Nases or for some other reasons.
Please Guys, Note that Whocares and me spend a lot of time working on those addons to make them work correctly on the new R6 firmware (New SDK, new problem, new desing ...) so it was for us a long run, not always easy. So if you like our addons please think on a donation.
Hope you will like all the new addons we have made.
I don't know on my side what will be Genie in the future, if everyone will use and like R6, but it's clear if genie is not used and the trick to bypass genie is used by everyone without return, I will think on finding a new way to provide addons. Please note, that I'm not a big fan of Genie, but that's the way Netgear ask us to provide addons. Please also note, so it will be clear that the price you see in Genie, it not the amount of money I will have in my pocket, Netgear take a part of it.
I never have done addons for money, but it's more and more time consuming , I consider donation as a "Thank you, continue your work" message. (Addons are done on free time)
Enjoy the addons, Enjoy the readynas
Poussin :arrow:
Poussin :arrow:
- GovnahAspirant
Govnah wrote: This seems 1/2 baked. Had to have Darth SSH into my RN516 to enable/fix the APPs tab, today in the logs I see "Volume: System volume 'root' usage is 95 %. This condition should not occur in normal conditions. Please contact technical support" (no idea why) and now this. I am on my second RN516, this first one the LCD/fron panel was defective.
I am about to the end of my rope........
Plex Media server is causing rootfs volume to fill up. I was watching a movie during that time period and just started another and noticed the rootfs volume to increase:
rootfs 4192192 1127888 2400224 32% /
...and that is only 5 minutes of watching a movie via Plex.
Stopped plex and back to normal:
rootfs 4192192 910004 2617484 26% / - mdgm-ntgrNETGEAR Employee RetiredDo you know where on the OS partition Plex is storing these files temporarily?
The solution to the issue used for 4.2.x doesn't appear to be used on ReadyNAS OS 6 at this time. - GovnahAspirantThis is just a guess, done for the night work in the AM....
root@ReadyNAS_516:/apps/plexmediaserver/MediaLibrary/Plex Media Server/Logs# - chirpaLuminaryIts a tricky area to get a fix. NTGR will blame Plex, Plex will make a fix right away if needed, but since its pre-installed, we would have to wait for the next 6.0.5/etc to have it included.
Darth Vader wrote: Please understand that ReadyNAS is just hosting the app, so if you have any issue with the app itself, please contact the developer (Author).
It looks like Plex does store some transcode files in /tmp/, which would trigger the issue you've encountered. - mdgm-ntgrNETGEAR Employee Retired/apps/plexmediaserver/plexmediaserver_environment specifies that the transcodes should be stored in /apps/plexmediaserver/tmp
The problem is this directory does not exist and it is using /tmp to store the transcodes.
Even if I create the directory and reboot the NAS it still uses /tmp
There are instructions here on how to manually change the temporary directory: http://forums.plexapp.com/index.php/topic/65594-custom-cache-location-for-transcoding-on-ubuntu/ (note the setting you need to change is visible if you turn on Advanced Settings)
After doing that
# cat /apps/plexmediaserver/MediaLibrary/Plex Media Server/Preferences.xml should give something like:
<?xml version="1.0" encoding="utf-8"?>
<Preferences MachineIdentifier="XXXX" ProcessedMachineIdentifier="YYYYY" AcceptedEULA="1" FirstRun="0" TranscoderTempDirectory="/apps/plexmediaserver/tmp"/>
Hopefully a fix can be made to properly set the Transcoder Temp Directory automatically on install. - AMRivlinApprenticeI have this root is full issue constantly. I just ignore them, because root isn't full when i check.
Interesting to find out it is related to Plex. When the new beta plex is released I will report back and let people know if it has been fixed. - chirpaLuminaryI just looked at AMR's box via SSH. Same issue, Plex filled /tmp with transcode files, root was full. This caused Dashboard to freak out in a never ending loop of 'connection lost', reloading the GUI over and over. The OS itself needs better error handling, it should have self-heal options to resolve this...
- tiranorAspirantIt should have /tmp on /c/ with warnings to prevent it from going over hundred of GB, too many apps use /tmp for their temporary content.
I have/had the same problem with php of 4.2, sometimes, ajaxplorer wrote the temporary file on /tmp instead of directly on the folder. I moved /tmp to /c/tmp and created a symlink, but i'm not really sure if it works perfectly. - chirpaLuminary
Not reliable. /tmp is used on boot too, before the RAID volume is mounted, could run into race issues.tiranor wrote: I moved /tmp to /c/tmp and created a symlink, but i'm not really sure if it works perfectly. - tiranorAspirantI just checked, it didn't survive the reboot, the symlink isn't there anymore, and i have a "new" /tmp folder.
