mfe_
Dec 05, 2012Tutor
Advice compiling php
Hello, I'm trying to compile php from source by using gcc 4.6.0 on the readynas duo sparc. I read the php.net manual which says I have to set the parameter --with-apxs2= The only apxs file I fou...
chirpa
Dec 05, 2012Luminary
WhoCares will probably have some input, he went through those growing pains awhile ago.
Do you need specific customized stuff? Looked at viewtopic.php?f=47&t=54543 ?
