mfe_
Dec 05, 2012Tutor
Advice compiling php
Hello, I'm trying to compile php from source by using gcc 4.6.0 on the readynas duo sparc. I read the php.net manual which says I have to set the parameter --with-apxs2= The only apxs file I fou...
mfe_
Dec 07, 2012Tutor
Hello, I need some customized extensions like mapi (for zarafa) and the pgsql extension. greetings
