mfe_
Dec 05, 2012Tutor
Advice compiling php
Hello, I'm trying to compile php from source by using gcc 4.6.0 on the readynas duo sparc. I read the php.net manual which says I have to set the parameter --with-apxs2= The only apxs file I fou...
WhoCares_
Jan 06, 2013Mentor
If it helps, I could provide you with the complete Apache .deb packages for the ReadyNAS. Of course you could also compile them from the GPL sources yourself. Using the apxs2 from that package should fix your problem I guess.
-Stefan
-Stefan
