mfe_
Dec 05, 2012Tutor
Advice compiling php
Hello, I'm trying to compile php from source by using gcc 4.6.0 on the readynas duo sparc. I read the php.net manual which says I have to set the parameter --with-apxs2= The only apxs file I fou...
mfe_
Jan 07, 2013Tutor
Thanks, I would like to use your apxs2 file and then try to compile it by my self. :)
greetings
greetings
