mfe_
Dec 05, 2012Tutor
Advice compiling php
Hello, I'm trying to compile php from source by using gcc 4.6.0 on the readynas duo sparc. I read the php.net manual which says I have to set the parameter --with-apxs2= The only apxs file I fou...
mfe_
Feb 05, 2013Tutor
Hi,
I got here some dependcy problem with apt-get and want to ask if i can do apt-get install -f without breaking the apache:
fes-a120d19nas:/backup/fes-a120d19nas/zarafa/gss-0.1.5# apt-get install -f
Reading Package Lists... Done
Building Dependency Tree... Done
Correcting dependencies... Done
The following extra packages will be installed:
libexpat1-dev libgnutls11 libldap2 libldap2-dev liblzo1 libopencdk8 libpcre3-dev libpcrecpp0 libsqlite3-dev libtasn1-2
Suggested packages:
gnutls-bin sqlite3-doc
The following packages will be REMOVED:
apache2-prefork-dev libapr1-dev libaprutil1-dev
The following NEW packages will be installed:
libexpat1-dev libgnutls11 libldap2-dev liblzo1 libopencdk8 libpcre3-dev libpcrecpp0 libsqlite3-dev libtasn1-2
The following packages will be upgraded:
libldap2
1 upgraded, 9 newly installed, 3 to remove and 75 not upgraded.
3 not fully installed or removed.
Need to get 1693kB of archives.
After unpacking 1847kB disk space will be freed.
Do you want to continue? [Y/n]
