ktw2017's avatar
ktw2017
Amazon Cloud Drive does not sync anymore
Hello,
I've been using Amazon Cloud Drive sync on my ReadyNas 6.6.0 for a couple of weeks, and it worked perfectly.
10 days ago, I've unfortunately switched off the service (under Cloud tab), and immediatly switched it on. Thus, the amazon sync service has stopped and restarted. Since then, it says he's looking for changes...
Using a new Amazon Cloud Drive account, and starting the synchronization with it... and it works! But that´s no solution. Any Ideas?
Firmware is now on 6.6.1, but same problem.
  • The error log was complaining about checkpoint not found and the last checkpoint was 'xxxxxx' some string. I added that last checkpoint to /var/cache/fvamazon/checkpoint.
  • Darth_Vader's avatar
    Darth_Vader
    NETGEAR Employee Retired
    When ACD service is restarted, it will restart the syncing process. Depending on how large your dataset, it might take a while to finish checking for changes. If you have a large dataset, I would suggest leaving it for a day or two and check back again.
    A new ACD account, on the other hand, has no content, so the upsync process will start right away.
    • ktw2017's avatar
      ktw2017
      That's not it. Before the deactivation / activation a new scan took about 25 min. Now, even after days, nothing happens and the process is running.
      • ktw2017's avatar
        ktw2017
        What files do you need? Found only the sqlite3 database (/var/cache/fvamazon/acd_fs_cache) which is created during sync - this remains however empty.
        In the /var/log/frontview/amazoncd.log is unfortunately only:
        - LOGMSG_CLOUDSTORAGE_SERVICE_START
        - LOGMSG_CLOUDSTORAGE_SEARCH_CLOUD_CHANGES_BEGIN
        Are there any more? Thanks.
ProSupport for Business
