AGSowjet
Jan 23, 2017Apprentice
Amazon Cloud drive sync stops while incomplete and switches to live synchronisation
Hi there, I am having a problem here with the Amazon Cloud drive sync using a ReadyNAS 104 with firmware 6.6.1 At the beginning all went smooth when I started synchronisation with 3.5 TB of data t...
FramerV
Jan 27, 2017NETGEAR Employee Retired
Hi AGSowjet,
Have you still been getting issues with the Amazon sync?
- AGSowjetJan 30, 2017Apprentice
I had to restart the initial syncing about 6 times in total, then finally it finished without errors and now is live syncing.
We have a second ReadyNAS 104 here, with another 5 TB to sync to Amazon Cloud. I hope we don't have to expect the same problems again…
There was no other error message than mentioned above, so I have no clue why it failed some times.
- FramerVJan 30, 2017NETGEAR Employee Retired
Hi AGSowjet,
Thanks for the feedback. You can post here if in case the 2nd ReadyNAS encounters an issue.
- Sep 06, 2016Retired_Member
