AGSowjet
Jan 23, 2017Apprentice
Amazon Cloud drive sync stops while incomplete and switches to live synchronisation
Hi there, I am having a problem here with the Amazon Cloud drive sync using a ReadyNAS 104 with firmware 6.6.1 At the beginning all went smooth when I started synchronisation with 3.5 TB of data t...
AGSowjet
Jan 30, 2017Apprentice
I had to restart the initial syncing about 6 times in total, then finally it finished without errors and now is live syncing.
We have a second ReadyNAS 104 here, with another 5 TB to sync to Amazon Cloud. I hope we don't have to expect the same problems again…
There was no other error message than mentioned above, so I have no clue why it failed some times.
FramerV
Jan 30, 2017NETGEAR Employee Retired
Hi AGSowjet,
Thanks for the feedback. You can post here if in case the 2nd ReadyNAS encounters an issue.
- Sep 06, 2016Retired_Member
