night_surfer
Sep 15, 2014Aspirant
amule installation and starting problem
Hi all,
i've found a problem un my RN104:
when i try to start amule (manually installed with the right arm package) the NAS system switch it off automatically after a few seconds and give me the following code error: 22002010000. I opened a ticket on NETGEAR support because i can't install the apps from the gui, i must install them manually to have a non-faulty installation, but another app (such antivirus plus) works well, and amule doesn't work even if the manual installation worked fine. can you give me some infos about this error code? i can provide also the config archive if can be helpful. I tried also on my company's readynas (that is a RN102 with same OS of mine) and amule got the same problems to start...maybe some bug...Any ideas?
Thanks very much...
Kind Regards
Filippo
Thanks very much...
Kind Regards
Filippo
- Tay1AspirantHello!
I have to come back on this issue.
ReadyNas 6.2.1
N104
I am able to install Amule from the web interface, but when I click ON it will give error message code error: 22002010000 and come back to OFF.
if I try ps aux | grep amule
the output is
root 8687 0.0 0.1 4140 804 pts/0 S+ 15:18 0:00 grep amule
there is no .aMule directory in /root/
Can somebody help? I really would like to use Amule on the server side of my NAS. - Tay1AspirantOk, just to let other people with the same problem know that I was able to get aMule up and running.
There are 2 commands you need to launch, as crazy72 reported:
amuleweb --amule-config-file=/data/amule/amule.conf &
/usr/bin/amuled -c /data/amule/ &
the program should be started with the "&" suffix, running in background
in my case "monit" program did not work, so I created an executable script and made it start at boot using rc.d
Enjoy aMule on ReadyNAS! - fabNASAspirantSince my knowledge are very limited I just reboot the readynas to factory, now amule works again on the latest firmware which is 6.2.2, let's see what will happen when will update the firmware again.
