NetWhiz
Jun 02, 2025Guide
Another strange Pro 6 OS 6 qwirk
SO, after rebuilding my Pro 6 with a factory default, the web GUI shows the above. It used to show the picture of teh Pro 6 and the model was filled in correctly. I do not know what happened or h...
- Jun 04, 2025
After getting back into the BOOT FLASH, I found that the VPD file was missing. So I copied it back over from my USB backup and now it is looking "normal" again.
Sandshark
Jun 02, 2025Sensei
They apparently screwed this up with the 6.10.9 release and didn't correct it in 6.10.10. As best I can tell, the pointer to the artwork is in a binary file, and I've been unable to find the artwork itself in and identifiable file type. You could look at the html source of the page and see if you can find it. I don't have a unit with that error in service any longer.
