NetWhiz's avatar
NetWhiz
Guide
Jun 02, 2025
Another strange Pro 6 OS 6 qwirk
SO, after rebuilding my Pro 6 with a factory default, the web GUI shows the above. It used to show the picture of teh Pro 6 and the model was filled in correctly. I do not know what happened or h...
  • NetWhiz's avatar
    NetWhiz
    Jun 04, 2025
    After getting back into the BOOT FLASH, I found that the VPD file was missing. So I copied it back over from my USB backup and now it is looking "normal" again.
ProSupport for Business
