NetWhiz
Jun 02, 2025Guide
Another strange Pro 6 OS 6 qwirk
SO, after rebuilding my Pro 6 with a factory default, the web GUI shows the above. It used to show the picture of teh Pro 6 and the model was filled in correctly. I do not know what happened or h...
- Jun 04, 2025
After getting back into the BOOT FLASH, I found that the VPD file was missing. So I copied it back over from my USB backup and now it is looking "normal" again.
Sandshark
Jun 03, 2025Sensei
You appear to have an issue with your VPD file. More typically, that causes the NAS to not even boot. It may be that you have one of the rare "no serial number" VPD files Netgear accidently sold some units with. With OS4.2.x, they then showed the MAC address as their serial number. But maybe OS6 doesn't. If this only occurred on a factory default, there is no reason your VPD should have been corrupted, as I believe your flash never gets write enabled during one.
NetWhiz
Jun 03, 2025Guide
It used to show fine. It was just since I did a USB Recovery to get back to booting (yes OS 6 version). I am thinking that I might try going into Tech Support mode and mounting the BOOT FLASH partition, check the VPD filesize, and copy back the backup I made of it before all this. We will see ...
- SandsharkJun 03, 2025Sensei
Ah, yes. USB recovery can corrupt the VPD file. You are lucky the unit is booting at all. See Backup and restore of VPD file for legacy ReadyNAS running OS6 | NETGEAR Communities before something more goes wrong.
- NetWhizJun 04, 2025Guide
