NetWhiz
Jun 02, 2025Guide
Another strange Pro 6 OS 6 qwirk
SO, after rebuilding my Pro 6 with a factory default, the web GUI shows the above. It used to show the picture of teh Pro 6 and the model was filled in correctly. I do not know what happened or h...
- Jun 04, 2025
After getting back into the BOOT FLASH, I found that the VPD file was missing. So I copied it back over from my USB backup and now it is looking "normal" again.
Sandshark
Jun 05, 2025Sensei
Hmmm. I wonder if that means that Netgear did away with the requirement for a valid VPD in legacy units running OS6 or that you just got lucky. I know people with corrupt VPDs have had issues with 6.10.9 and 6.10.10, but maybe the solution now is just to delete it (and put up with that oddity).
