NAStools
Mar 23, 2016Luminary
Apps by NAStools
Hi, everyone!
I've made some updates to a few already available apps, and released some new ones.
See below for download links (click the Version link). amd64 for Intel units, armel for M...
gyves1
May 02, 2016Luminary
Hi NAStools,
I have installed the Transmission NT 2.92-nt2, I have two questions:
1) I would like to save the downloaded file in the previous folder from the older Transmission App (from Poussin), but I receive an error message as "access denied"
2) I use a windows UI to manage the Transmission server (remotly), I need to know the admin login infos to setup the Windows UI, where can I found this infos?
Thanks
- NAStoolsMay 02, 2016Luminary
gyves1 wrote:1) I would like to save the downloaded file in the previous folder from the older Transmission App (from Poussin), but I receive an error message as "access denied"
Make sure the nastools-transmission user has access to the share under its "File Access" settings.
Host: Your NAS' IP address or hostname
Port: 443
SSL: Yes
User/pass: Either the NAS admin user, or a local user that is a member of the nastools-transmission group.
RPC path: /apps/nastools-transmission/rpc
- cnecneMay 03, 2016Aspirant
Hi, thank you for the new version of LMS 7.9!
I have a problem with the online downsampling of files.In Version 7.7.3, which i used before, all files (flac) where resampled to the max rate used by my squeezeboxes.
Now, in your version, i cannot play any files with a higher samplerate as the native palyable rate!
Is there any chance to change this beahiour?
Thank in advance, Christoph
So, another idea:
I started ldd ./sox on the commandline
/apps/nastools-logitechmediaserver/slimserver/Bin/x86_64-linux$ ldd ./sox
linux-vdso.so.1 (0x00007ffc99685000)
libgomp.so.1 => not found
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fb8a2e59000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fb8a2c3b000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fb8a2892000)
/lib64/ld-linux-x86-64.so.2 (0x0000561696b58000)and found that libgomp.so.1 is missing!
Is it possible, that the missing lib prevents from transcoding?
Can I install the missing lib?
Please Help, Christoph
