NAStools
Mar 23, 2016Luminary
Apps by NAStools
Hi, everyone!
I've made some updates to a few already available apps, and released some new ones.
See below for download links (click the Version link). amd64 for Intel units, armel for M...
cnecne
May 03, 2016Aspirant
Hi, thank you for the new version of LMS 7.9!
I have a problem with the online downsampling of files.
In Version 7.7.3, which i used before, all files (flac) where resampled to the max rate used by my squeezeboxes.
Now, in your version, i cannot play any files with a higher samplerate as the native palyable rate!
Is there any chance to change this beahiour?
Thank in advance, Christoph
cnecne
So, another idea:
I started ldd ./sox on the commandline
/apps/nastools-logitechmediaserver/slimserver/Bin/x86_64-linux$ ldd ./sox
linux-vdso.so.1 (0x00007ffc99685000)
libgomp.so.1 => not found
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fb8a2e59000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fb8a2c3b000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fb8a2892000)
/lib64/ld-linux-x86-64.so.2 (0x0000561696b58000)
and found that libgomp.so.1 is missing!
Is it possible, that the missing lib prevents from transcoding?
Can I install the missing lib?
Please Help, Christoph
- NAStoolsMay 03, 2016Luminary
/lib64/ld-linux-x86-64.so.2 (0x0000561696b58000)and found that libgomp.so.1 is missing!
You are correct, thanks for the details! You can manually install the libgomp1 package for now. Fix is in v7.9.0.b7dfc80-nt2.
- cnecneMay 03, 2016Aspirant
Thank you for the quick response, NAStools!
Pleas can you tell me how to install the package, i am new to linux!
Should i upload the package to my nas and than?
Help is welcome!
Christoph
cnecne wrote:Pleas can you tell me how to install the package, i am new to linux!
A simple apt-get install libgomp1 should do it for you, or upgrade to the v7.9.0.b7dfc80-nt2 package I just released. :)
