NAStools
Mar 23, 2016Luminary
Apps by NAStools
Hi, everyone!
I've made some updates to a few already available apps, and released some new ones.
See below for download links (click the Version link). amd64 for Intel units, armel for M...
rube
Jun 04, 2016Aspirant
Could you tell me what the default login and password is for transmission nt?
NAStools
Jun 04, 2016Luminary
rube wrote:Could you tell me what the default login and password is for transmission nt?
NAStools wrote:Local admin, local users added to the group nastools-transmission, and the ReadyCLOUD admin are able to login.
- northernlightsJun 08, 2016Aspirant
Hello,
Where I can find the downloaded files on my NAS? When I open the shares window there is no transmission folders there, I can see that there are some data on the drive, but couldn't find folders from the dowload path of the transmission client. I have FW 6.5.0.
Thanks,
- JennCJun 08, 2016NETGEAR Employee Retired
Hello northernlights,
When you map the NAS IP, there should be a new share created, Transmission is the share name. You should also see it when you go to admin page of the NAS then click Shares.
Hello,
that what is weird. When I go to admin page of my NAS there is no Transmission folder under shares. Same if I try to connect via explorer there is no Transmission folder only the ones I created.
Thanks.
- NAStoolsJun 08, 2016Luminary
northernlights wrote:Where I can find the downloaded files on my NAS? When I open the shares window there is no transmission folders there, I can see that there are some data on the drive, but couldn't find folders from the dowload path of the transmission client. I have FW 6.5.0.
The default directory downloads are saved to is /apps/nastools-transmission/downloads. You can access this folder by logging in to the NAS as the local admin user over SMB (if you still have the default admin password you'll need to change this before you're allowed to login). Access the volume share and drill down to .apps\nastools-transmission\downloads. You may need to turn on viewing of hidden files to see the .apps directory.
You're more than welcome to create a share via the ReadyNAS UI and then set your Transmission settings to use this share as the default download location.
JennC wrote:When you map the NAS IP, there should be a new share created, Transmission is the share name. You should also see it when you go to admin page of the NAS then click Shares.
This information is for Poussin's transmission. It is not applicable to my Transmission NT add-on.
- northernlightsJun 09, 2016Aspirant
Hello,
Thank you for the explanation of the dowload path. I didn't know there are some hidden files and folders.
