NAStools
Mar 23, 2016Luminary
Apps by NAStools
Hi, everyone!
I've made some updates to a few already available apps, and released some new ones.
See below for download links (click the Version link). amd64 for Intel units, armel for M...
abe_cologne
Jul 31, 2016Aspirant
- FW 6.5.1
- App: "Transmission for Readynas" 3.00.8 by Poussin
Hi there!
I've been using the Transmission App on this ReadyNAS and it's Predesessor (old Sparc Model, still works but not enough capacity) and I grew very fond of it.
I know that you have been making an adapted version and I would be willing to give it a try if it can meet my needs:
- setting the seeding speed to "0"
- any form of automated adding of torrents, preferbly RSS (extratorrent)
The first option is an absolout must. In the country I life in torrent users are hunted by lawer firms and the law says it is illegal as soon as you start to distribute (seed). On a side note- I only download torrents wich are already seeded in the thousends (popular TV torrents)
The second option may me achived by "Automatic for Bittorent" or some similiar tool.
Thank you so much for your effort and service to such a great community!
Cheers abe
NAStools
Aug 09, 2016Luminary
abe_cologne wrote:- setting the seeding speed to "0"
According to a post on the Transmission forum you can disable seeding globally under Settings > Torrents > Seeding > Stop seeding at ratio. Set this to 0.
Would require a separate application, there's a few out there. As long as it supports Transmission's remote RPC protocol it should work fine.
lteska2 wrote:When I edit /etc/settings.json in nas-tools folder it stays modified only until I restart the service. After turning off and on transimssion service, the orignal settings are being brought back. None of my changes stays after restarting. What I am doing wrong?
According to the Transmission wiki: "The client should be closed before making changes, otherwise settings will be reverted to it's previous state."
- jhaggSep 22, 2016Luminary
NASTools, I sent you a PM about a project request a few weeks back if you can check it and get back to me, thanks.
- pfdwyerJan 14, 2017Aspirant
I'm still not able to reach the share and I'm not sure of the syntax if I want to change it.
I can see a new share called nastools-transmission but I can't access it with any account in the readynas. I've added accounts to the nastools-transmission group and restarted as well. Also tried the \download.
The default is still /apps/nastools-transmission/downloads
If I create a new share in the webUI and call it "downloads" what would the full path be from the transmissions web gui to change it to? I don't really know the inside of debian linux to know where they have put these shares.
Thanks
- FramerVJan 15, 2017NETGEAR Employee Retired
Hi pfdwyer,
What firmware are currently using?
Might be best if you update it first. Sending a PM might also give you a faster response from the developer.
ReadyNAS OS 6 Software Version 6.6.1
- pfdwyerJan 16, 2017Aspirant
Thanks,
I am using 6.6.1.
