NAStools
Mar 23, 2016Luminary
Apps by NAStools
Hi, everyone!
I've made some updates to a few already available apps, and released some new ones.
See below for download links (click the Version link). amd64 for Intel units, armel for M...
Sandshark
Oct 22, 2016Sensei
ZeroTier does sound intriguing. If I'm reading their documentation right, it would allow access to a ReadyNAS, including backup jobs between locations, via the VPN but not route all traffic through it (unless that's your desire). Let me know if you need any testers, as I have one NAS I use for such things.
In the meantime, a guide to manually installing it would be appreciated. The CLI doesn't scare me, but it's unclear to me from only their site what I need to install to assure I have all dependancies.
NAStools
Nov 01, 2016Luminary
Sandshark wrote:ZeroTier does sound intriguing. If I'm reading their documentation right, it would allow access to a ReadyNAS, including backup jobs between locations, via the VPN but not route all traffic through it (unless that's your desire). Let me know if you need any testers, as I have one NAS I use for such things.
jaredbidlow wrote:I found this guide: https://www.andrewmunsell.com/blog/remote-access-to-readynas-zerotier-one/
I would also like the dedicated app compatible with ARM Readynas devices
Still working on the web frontend for it, but since there's interest I'll put out a CLI only package first.
jhagg wrote:Mhynlo started packaging NZBGet for 6.6.0 but has since gone dark on it or I wouldn't have bothered you with it, currently there is no solution in place.
I talked to Mhynlo, he's just putting the finishing touches on it. :robothappy:
ghidin wrote:Since the firmware has upgraded to 6.6.0 the zoneminder NT cannot install. Do you have upgrade package or the solution for this issue.
Yes I do! I'll have siigna update my original post. New version for 6.6.0 is v1.30.0-nt2.
- NAStoolsNov 01, 2016Luminary
- Space-FireNov 03, 2016Aspirant
Hi,
Thank you for the iStat deb file I don't think I would have had the skills to build it from the dev file. I have installed it and it works great however...
Please could you walk me through changing the password.
I don't appear to have a an /apps directory on my ready nas. where is the dir im looking for sorry if my question seems a stupid question.
- Default password is 12345. This can be changed by modifying server_code in /apps/nastools-istat/etc/istatserver/istatserver.conf.
Thanks,
JJ
Derp... I was missing the ls -a command to list hidden files ... lol nm I got this
- grimlochNov 04, 2016Aspirant
I tried installing nastools-istatserver_3.0-nt1_amd64.deb on my ReadyNAS Pro running 6.5.0 and get the error "Cannot install application nastools-istatserver_3.0-nt1_amd64.deb". I did uninstall the old istat.
Sandshark, jaredbidlow, give this ZeroTier package a try. :robothappy:
