NAStools
Mar 23, 2016Luminary
Apps by NAStools
Hi, everyone!
I've made some updates to a few already available apps, and released some new ones.
See below for download links (click the Version link). amd64 for Intel units, armel for M...
NAStools
Nov 01, 2016Luminary
Sandshark wrote:ZeroTier does sound intriguing. If I'm reading their documentation right, it would allow access to a ReadyNAS, including backup jobs between locations, via the VPN but not route all traffic through it (unless that's your desire). Let me know if you need any testers, as I have one NAS I use for such things.
In the meantime, a guide to manually installing it would be appreciated. The CLI doesn't scare me, but it's unclear to me from only their site what I need to install to assure I have all dependancies.
jaredbidlow wrote:I found this guide: https://www.andrewmunsell.com/blog/remote-access-to-readynas-zerotier-one/
I would also like the dedicated app compatible with ARM Readynas devices
Still working on the web frontend for it, but since there's interest I'll put out a CLI only package first.
jhagg wrote:Mhynlo started packaging NZBGet for 6.6.0 but has since gone dark on it or I wouldn't have bothered you with it, currently there is no solution in place.
I talked to Mhynlo, he's just putting the finishing touches on it. :robothappy:
ghidin wrote:Since the firmware has upgraded to 6.6.0 the zoneminder NT cannot install. Do you have upgrade package or the solution for this issue.
Yes I do! I'll have siigna update my original post. New version for 6.6.0 is v1.30.0-nt2.
NAStools
Sandshark, jaredbidlow, give this ZeroTier package a try. :robothappy:
