NAStools
Mar 23, 2016Luminary
Apps by NAStools
Hi, everyone!
I've made some updates to a few already available apps, and released some new ones.
See below for download links (click the Version link). amd64 for Intel units, armel for M...
jaredbidlow
Nov 02, 2016Aspirant
what is the advantage of LMS over Plex? Should I install LMS if I already use Plex? Does LMS serve music better than Plex and also support Chromecast audio?
- NAStoolsNov 02, 2016Luminary
jaredbidlow wrote:
what is the advantage of LMS over Plex? Should I install LMS if I already use Plex? Does LMS serve music better than Plex and also support Chromecast audio?I can't comment on which is better, but LMS is definitely what you want to use if you have any Squeezebox type devices.
It does look like somebody is supporting Chromecast Audio via an LMS plugin. I'll look into this!
