NAStools
Mar 23, 2016Luminary
Apps by NAStools
Hi, everyone!
I've made some updates to a few already available apps, and released some new ones.
See below for download links (click the Version link). amd64 for Intel units, armel for M...
Retired_Member
Nov 05, 2016Hi, everone!
Unfortunately, I still have the same problem with zoneminder. I've tried many version and none of them work.
Someone can help me? thankyou.
- StephenBNov 05, 2016Guru - Experienced User
ghidin wrote:
Hi, everone!
So what NAS do you have and what firmware is it running?
- Retired_MemberNov 06, 2016
I have RN 314 with the firmware 6.6.0. I tried install many versions,
1.30.0-nt1_amd64
1.30.0-nt2_amd64
dbg_1.30.0-nt1_amd64
dbg_1.30.0.RC2-nt1_amd64
- StephenBNov 06, 2016Guru - Experienced User
1.30.0-nt1_amd64
1.30.0-nt2_amd64
Did you try nastools-istatserver_3.0-nt1_amd64.deb from https://github.com/NAStools/istatserver/releases ?
- NAStoolsNov 07, 2016Luminary
ghidin wrote:Hi, everone!
v1.30.0-nt2 is the version you want for firmware 6.6.0. Can you download your system logs (System > Logs > Download logs) and PM me the install_debpkg.log?
- harryrichardfoeJun 05, 2017Guide
Hello NAStools.
Really appreciate the addons that you have developed. It seems that the Readnas firmware has been changing very quickly and is currently at 6.7.4 which has brought forth a few issues.
One being that Zoneminder v1.30.0-nt2 has stopped working. It currently is unable to start (error code 22002010000) and also can not be downloaded and installed from the available apps page.
Can Zoneminder be updated for whatever changed in firmware 6.7.4 ?
Thanks
- Retired_MemberJun 05, 2017
I have the same problem with zoneminder
Firmware 6.7.4 - ReadyNAS 314
