NAStools
Mar 23, 2016Luminary
Apps by NAStools
Hi, everyone!
I've made some updates to a few already available apps, and released some new ones.
See below for download links (click the Version link). amd64 for Intel units, armel for M...
m-frank
Dec 03, 2016Aspirant
I just installed Logitech Media Server NT and everything works fine, except i cant WOL my ReadyNAS 516 from LMS like I used to when I had installed Poussin version of LMS.
Is there a solution to the WOL problem?
ReadyNAS 516
OS 6.6
FramerV
Dec 05, 2016NETGEAR Employee Retired
Hi m-frank,
Might be best if you get in touch with the developer. Also, if its not too much; would you be able to uninstall the app then try the WOL? Just for isolation.
