NAStools
Mar 23, 2016Luminary
Apps by NAStools
Hi, everyone!
I've made some updates to a few already available apps, and released some new ones.
See below for download links (click the Version link). amd64 for Intel units, armel for M...
nycaleksey
Jul 18, 2017Aspirant
Hi,
Thank you very much for packages these great apps. It seems like Zoneminder is broken on v6.7.5. Are there any plans to update it for the latest OS?
Marty_M
Jul 27, 2017NETGEAR Employee Retired
nycaleksey,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
NETGEAR Community Team
- Retired_MemberAug 18, 2017
Let me guess!!
Zoneminder is free and isn't working because the netgear has the Arcus to sell.
ASUSTOR I'm sorry.
- JBDragon1Aug 18, 2017Virtuoso
You know, you may be right about that! But I'm sure ZoneMinder could be made to work just fine once again with a little effort. Then again, you get it working, and then a new Update screws it up once again.
- harryrichardfoeSep 12, 2017Guide
The ReadyNas firmware updates revises the OS included packages. When trying to install Zoneminder NT, the systemd-journal.log reports the following error: "The following packages have unmet dependencies: nastools-zoneminder : Depends: libjpeg8 (>= 8c) but it is not going to be installed", and then aborts the installation. The loaded OS has libjpeg62-turbo package already and therefore doesn't allow the libjpeg8 package to be installed that Zoneminder requires for this build. There maybe other dependencies that Zoneminder requires that are incompatible with the installed Readynas OS. A new Zoneminder build is required for ReadyNas firmware 6.8.0 OS.
