NAStools
Mar 23, 2016Luminary
Apps by NAStools
Hi, everyone!
I've made some updates to a few already available apps, and released some new ones.
See below for download links (click the Version link). amd64 for Intel units, armel for M...
cnecne
Sep 03, 2017Aspirant
Hi,
i use LMS 7.9.0 from nastools and would like to know, if anybody has updated his RN-516 to firmware 6.8.0.
Using firmware 6.6.1 everything is just working fine, and it would be bad if LMS is not compatible with the last firmware release.
So anybody anykind of notes about the last firmware and LMS?
Many regards
Christoph
givememynamebak
Sep 03, 2017Luminary
I use ReadyNAS Pro6 (also intel processor) and it works fine with NasTools LMS 7.9.0 on my Boom, Touch and Duet. There's also a 7.9.1 version here: http://downloads.slimdevices.com/nightly/index.php?ver=7.9 The only issue would be making sure it installs in the apps directory if you install the packages directly. Here's the changelogs: http://htmlpreview.github.io/?https://github.com/Logitech/slimserver/blob/public/7.9/Changelog7.html
