prashant11
Oct 27, 2016Aspirant
AWS cloud sync
Hello, I signed up for Amazon cloud storage so that I can have files backed up to cloud. It works great, except for one thing. When i sometimes go and clean up my NAS (delete unwanted files), i...
FramerV
Oct 28, 2016NETGEAR Employee Retired
Hi prashant11,
As far as I know, Amazon cloud sync is two-way sync and if my understanding of it is correct; the most recent change/deletion from one side should sync to the other side.
Have you made some tests? Like what if you deleted a file on the Amazon cloud, would it show on the NAS? Also, try adding files on the NAS and see if it will be created on the Amazon cloud.
- prashant11Nov 03, 2016Aspirant
So for some reason it kept downloading things from AWS to the NAS once I deleted it on the NAS, but I did a code upg to the latest, and now it is working as it should.
Appreciate your reply. Thanks.
- FramerVNov 03, 2016NETGEAR Employee Retired
Hi prashant11,
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
