UncleBFester
Apr 20, 2022Aspirant
ReadyNAS 214 One Drive Cloud sync issues
Ready NAS 214
6.10.7
Got some challenges with this with old sync data. So on the NAS - I've disabled the sync / deleted the OneDrive content / disabled snapshots. On One Drive - I've deleted everything / emptied the bin / let it all resync
One Drive Cloud Sync app on the NAS is reporting storage in use - 775Gb of 1Tb available
One Drive app on my phone shows 387Gb of data synced
365 Cloud admin portal shows just under 610Gb data stored of 1Tb available
One Drive Storage used in my 365 user admin portal says 51.8Gb used out of 1Tb available
Actual local File Data to sync - 387.5Gb
I can't work out why there is such a massive difference between the reported figures. My gut feeling is that 51Gb is the actual space in use after compression at the OneDrive server end. The other figures are the uncompressed ones and that the NetGear NAS is simply fibbing about the actual amount in use.
Or the changes i've made / fixed file sync are just taking their sweet time to ripple out through the various reporting functions.
Has anyone else noticed this / found a fix for it?
Cheers,
Patrick
https://www.kingcomputer.com.au/disable-sharepoint-and-onedrive-version/
https://www.enjoysharepoint.com/connect-sposervice-current-site-is-not-a-tenant-administration-site/
Follow the above to disable versioning on your site.
Delete the sync data
Re-enable the sync.
What an absolute crock of proverbial on Microsofts part and a right ballache to find the fix for.
I don't use the app, but have some general thoughts about space.
Did you delete the snapshots on the NAS, or just disable creation of new ones?
Also, it's often useful to run a balance from the volume settings wheel when the amount of space doesn't seem to add up.
In some cases, turning volume quota off and then on again (also on the volume settings wheel) can fix space accounting issues.
- UncleBFesterAspirant
Hi Stephen,
Yes, i went in and manually deleted the snapshots as well as disabling new ones. Typically I can't now find the raw data folder structure i was looking at last night.
I really do hate 365 with a passion, it's almost as bad as Lotus Domino server was!
UncleBFester wrote:Yes, i went in and manually deleted the snapshots as well as disabling new ones.
Then maybe try the balance next.
