UncleBFester
Apr 20, 2022Aspirant
ReadyNAS 214 One Drive Cloud sync issues
Ready NAS 214 6.10.7 Got some challenges with this with old sync data. So on the NAS - I've disabled the sync / deleted the OneDrive content / disabled snapshots. On One Drive - I've deleted e...
- Apr 21, 2022
https://www.kingcomputer.com.au/disable-sharepoint-and-onedrive-version/
https://www.enjoysharepoint.com/connect-sposervice-current-site-is-not-a-tenant-administration-site/
Follow the above to disable versioning on your site.
Delete the sync data
Re-enable the sync.
What an absolute crock of proverbial on Microsofts part and a right ballache to find the fix for.
Apr 20, 2022Guru - Experienced User
I don't use the app, but have some general thoughts about space.
Did you delete the snapshots on the NAS, or just disable creation of new ones?
Also, it's often useful to run a balance from the volume settings wheel when the amount of space doesn't seem to add up.
In some cases, turning volume quota off and then on again (also on the volume settings wheel) can fix space accounting issues.
UncleBFester
Hi Stephen,
Yes, i went in and manually deleted the snapshots as well as disabling new ones. Typically I can't now find the raw data folder structure i was looking at last night.
I really do hate 365 with a passion, it's almost as bad as Lotus Domino server was!
- StephenBApr 20, 2022Guru - Experienced User
UncleBFester wrote:Yes, i went in and manually deleted the snapshots as well as disabling new ones.
Then maybe try the balance next.
- UncleBFesterApr 20, 2022Aspirant
Gone back to the 365 One Drive folders, disabled sync and then deleted the sub and top level folders in One Drive and recreated them from the ReadyNAS - sync now re-running.
Will see if that's resolved the problem
On the smaller of the 3 folders ( about 9gb) so far 9gb is recording at both NAS and Cloud which is correct.
- UncleBFesterApr 21, 2022Aspirant
Re-enable the sync.
