prashant11
Oct 27, 2016Aspirant
AWS cloud sync
Hello, I signed up for Amazon cloud storage so that I can have files backed up to cloud. It works great, except for one thing. When i sometimes go and clean up my NAS (delete unwanted files), i...
prashant11
Nov 03, 2016Aspirant
So for some reason it kept downloading things from AWS to the NAS once I deleted it on the NAS, but I did a code upg to the latest, and now it is working as it should.
Appreciate your reply. Thanks.
FramerV
Nov 03, 2016NETGEAR Employee Retired
Hi prashant11,
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
