ismaeljk
Apr 05, 2019Tutor
Backing up to ReadyNAS Vault some files/folders are not backed up
We have a backup from a ReadyNAS 524X running firmware 6.9.3 backing up to a ReadyNAS Vault.
On some of the backups, when new folders are created but not all, files in those folders are not bac...
- Apr 16, 2019
What worked in the end was upgrading the vault software running on the ReadyNAS - see this article.
But beware, when I upgraded the ReadyNAS OS, it seemed to overwrite the update, and I had to update it again.
Apr 05, 2019Guru - Experienced User
Of course that should work.
I am wondering if you tried resetting the file ownership and permissions on the share? That should reset permissions recursively, which might solve the problem.
ismaeljk
Apr 08, 2019Tutor
Thanks Stephen,
Unfortunately that did not work...
- StephenBApr 08, 2019Guru - Experienced User
Did you email [email protected] ???
- ismaeljkApr 08, 2019Tutor
Yes, when we have a resolution I will post it...
- ismaeljkApr 16, 2019Tutor
