ismaeljk
Apr 05, 2019Tutor
Backing up to ReadyNAS Vault some files/folders are not backed up
We have a backup from a ReadyNAS 524X running firmware 6.9.3 backing up to a ReadyNAS Vault.
On some of the backups, when new folders are created but not all, files in those folders are not bac...
- Apr 16, 2019
What worked in the end was upgrading the vault software running on the ReadyNAS - see this article.
But beware, when I upgraded the ReadyNAS OS, it seemed to overwrite the update, and I had to update it again.
ismaeljk
Apr 08, 2019Tutor
Thanks Stephen,
Unfortunately that did not work...
Apr 08, 2019Guru - Experienced User
Did you email [email protected] ???
- ismaeljkApr 08, 2019Tutor
Yes, when we have a resolution I will post it...
- ismaeljkApr 16, 2019Tutor
