tiborszabo
Sep 26, 2019Star
Backing up to Wasabi from ReadyNAS 316
Hi all, I've been trying to get a ReadyNAS 316 backing up to Wasabi in a stable fashion. It's been a bit of a struggle as I just discovered that the NAS only syncs, and therefore always propagat...
JohnCM_S
Sep 27, 2019NETGEAR Employee Retired
Hi tiborszabo,
I also tried setting up an immutable bucket on Wasabi and sync it to the NAS. It behaves as it should be on my end. The files are retained on the Wasabi bucket when I delete the files on the NAS.
May I know the current firmware of your NAS? May I also know the sync direction configured?
JohnCM_S
Oct 01, 2019NETGEAR Employee Retired
Hi tiborszabo,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as a solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
