nhasenoehrl
Jan 06, 2021Aspirant
Cannot activate Antivirus
Hi, I am experiencing Ransomware attacks and I would like to know how to activate Antivirus on my ReadyNAS system. I know that the option SHOULD appear in System-->Settings-Services but unfortunatel...
- Jan 06, 2021
Well, that would explain it. But I can always use ZoneAlarm and check the NAS over the Local Network, takes a long time, though.
Jan 06, 2021Guru - Experienced User
What ReadyNAS model do you have, and what firmware are you running on it?
nhasenoehrl
It's a ReadyNAS 104 with the latest firmware (6.10.4).
- rn_enthusiastJan 06, 2021Virtuoso
I believe Netgear removed the Anti-virus service from the RN100 series NAS, due to them being too underpowered to run it properly. I think this was done since the 6.10.x firmwares.
- nhasenoehrlJan 06, 2021Aspirant
- SandsharkJan 06, 2021Sensei
If all computers that have write access to the NAS have active protection, it is unlikely that an infected file will end up on it. As an additional safeguard, don't leave an open connection to the NAS when not in use.
