edwardleijen
Jul 10, 2017Aspirant
cannot install zoneminder on rn102 running 6.7.5 firmware
hello i have some trouble with installing zoneminder. when i download the app the install screen popup saying in dutch that de files are being downloaded. after a while the message pops up cannot i...
Marty_M
Jul 11, 2017NETGEAR Employee Retired
Hello edwardleijen,
It is possible that the version of the app is not yet compatible with the ReadyNAS OS6 latest firmware version. You might want to seek to assistance from the developer of the app so they can update the app then submit to Netgear for review.
In any case that the app is not yet compatible with the new firmware, it is the developer that should update their app and submit it to Netgear.
Welcome to the community!
Marty_M
NETGEAR Community Team
- Marty_MJul 16, 2017NETGEAR Employee Retired
Hello edwardleijen,
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance. If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
NETGEAR Community Team- edwardleijenJul 16, 2017Aspirant
Sure the problem is solved.
I bought a Synology NAS with more apps VPN and Surveillance run great.
RN102 runs still but will be sold on the second hand market place.
