Rod101
Jan 10, 2018Follower
Cant connect to ReadyNas NV+ v2 SMB1 Protocol ??
Hi. I've been having a few computer issues recently that I thought had caused an issue with accessing my NAS drive. I've been trying to fix this and been struggling until earlier. My Windows 10 lapto...
- Jan 10, 2018
SMBPlus is only for OS 6 NAS, and you are running OS 5 (that is, 5.3.x firmware). It wouldn't help with this anyway, as your NAS only supports SMB1.
What you have to do is re-enable the SMB1 client in your Windows 10 PCs. If you go into add/remove programs, and look at the windows features, you should see an option to install "SMB 1.0/CIFS File Sharing Support". If you install that, you'll have access to the NAS again (accepting the security risk of running an SMB client).
While you are in there, you can also check to see if your Windows version includes an NFS client. You could also install that, and enable NFS on the NAS.
Jan 10, 2018Guru - Experienced User
