Mystprism
Nov 20, 2019Follower
Can't get ReadyNAS 212 working with ReadyNAS Vault
Running a ReadyNAS 212 on Firmware 6.10.2 (latest). I had it set up with ReadyNAS vault to do continuous backups. That suddenly stopped working (files "last modified" date just stayed the same). I co...
- Jan 24, 2020
Thanks - updating the Vault software on the NAS using this link has resolved this:
KimReadyNAS
Jan 23, 2020Aspirant
Did you ever get this sorted? I have exactly the same issue. Like you, I saw an illustration online of a VAULT tab under the BACKUP tab of the NAS, but it is not there on my NAS even after I login to the Vault under the CLOUD tab.
Thanks so much!
- StephenBJan 23, 2020Guru - Experienced User
Use JohnCM_S' link to contact the vault support team.
- ReadyNASVaultEDJan 23, 2020Guide
Hi - sorry about the delay - we just got wind of this thread.
Please do either use the link or just write to us at [email protected]. The inbound email will automatically create a trackable ticket.
At a high level, we just need to help you update to the latest version of the Vault software. From the device, all you need to do is login, which will register a new device or authenticate and connet an existing one. Then all configuration can be done via the web at https://vault.readynasvault.com/.
Please be sure to include the email address of your Vault account if you already have one.
Thanks - and looking forward to getting this resolved for you as quickly as possible.
Best,
ReadyNAS Vault Team
- KimReadyNASJan 24, 2020Aspirant
