scotty134
Apr 08, 2019Aspirant
Configuring SoftEther VPN on Netgear NAS 626x
Hello,
I have a question how I can configure SoftEther on my Netgear 626x? I saw in APPs that I can install SoftEther VPN, but it's no lunch button for this. How I can configure this VPN server...
Sandshark
Apr 08, 2019Sensei
I used it quite some time ago. If I remember correctly, it sets up a share that contains the configuration files so you can gain access to them without dropping to SSH. But I think it's also a pretty ancient version.
I switched to ZeroTier, but the ReadyNAS-specific version of that is also long in the tooth, now.
scotty134
So looks like I have to go with VPN on router or to install VPN Server on one of my severs.
- SandsharkApr 08, 2019Sensei
On the router usually works best. Alternately, you could install an updated version via SSH. But you need to take care you don't leave it a way to fill the OS partition (with logs, for example). And that doesn't solve the issue of configuring through something other than SSH.
- scotty134Apr 09, 2019Aspirant
Thank you!
