arnomc
Oct 27, 2013Aspirant
Contacts&Calendars for RN6: Baikal & iOS no cardDAV sync !!
Has anyone tried this add-on based on Baïkal ? I installed it and then configured it with success on OS X (Mavericks) for both CalDAV and CardDAV (http without SSL). I also figured it out on iPhone f...
arnomc
Oct 28, 2013Aspirant
Thanks for your answers super-poussin (fast as usual). So when I tried baikal on my RN 6.1.4, the sync didn't worked for another reason (I will investigate further).
The front button to reboot or shutdown didn't worked so I SSH "rn_shutdown", wait a bit then the NAS yelled me to "Use 'reboot' command to reboot"
But it didn't shudown at all. I tried "reboot" and it absolutely nothing. So I pressed more than 4 sec on the power button on the front of my Ultra2, and it did shut it down instantly like a PC.
Now after a "cold boot" I have again access to the webadmin :D The readynas was just stuck for no reason in the end of the shutdown.
Thanks Poussin.
Does "istat" needs PHP to work ? While I have it I could try this add-on :)
And I'll try again Baikal : I really need a solution for Mavericks which doesn't include anymore any sync services for local backup of iOS devices.
Thanks Poussin.
