arnomc
Oct 27, 2013Aspirant
Contacts&Calendars for RN6: Baikal & iOS no cardDAV sync !!
Has anyone tried this add-on based on Baïkal ? I installed it and then configured it with success on OS X (Mavericks) for both CalDAV and CardDAV (http without SSL). I also figured it out on iPhone f...
mdgm-ntgr
Oct 28, 2013NETGEAR Employee Retired
To reboot you could do
To safely shutdown the NAS using the power button you need to press it briefly twice.
Pressing and holding the power button for ~ 5 seconds would forcibly shutdown the NAS.
It is possible to restart the Dashboard without needing to reboot. See this thread: http://www.readynas.com/forum/viewtopic.php?f=65&t=71773&p=398678#p398678
# rn_shutdown -r
