arnomc
Oct 27, 2013Aspirant
Contacts&Calendars for RN6: Baikal & iOS no cardDAV sync !!
Has anyone tried this add-on based on Baïkal ? I installed it and then configured it with success on OS X (Mavericks) for both CalDAV and CardDAV (http without SSL). I also figured it out on iPhone f...
arnomc
Feb 27, 2014Aspirant
I finally obtain half a success on my quest :D. I configured an account without SSL, edit the adress like sjuul said, and iOS gave me the warning that it will probably not work ; but in fact the sync is effective !
Then I decided to try for SSL.
1) I edited the working account to activate SSL using the port 7500 :port used by the add-on (see the add-on help). but it didn't worked.
2) then a recreate the account from the beginning but this time without accepting to switch to non-SSL connection when the iphone warned me. It neither worked :(.
I really would like to be able to use SSL, that would allow me to replace in the setting my local LAN IP address with my full address and avoid sending request to the 192.168... each time I connect my iOS through 3G or a hotspot :/
Otherwise could I install a VPN server on my NAS ? then connect my iphone to my vpn and then use my local LAN IP address in Baïkal settings like it is currently ?
Thanks for you help, I finally could go a little forward.
