bte4's avatar
bte4
ddclient setup on RN102
Trying to set up ddclient on RN102 and can't seem to figure it out. Currently running latest firmware 6.1.6. Downloaded and installed without a problem. However the "launch" button is grayed out. Toggling on and off does nothing. Maybe that's the problem?
Edited ddclient.conf file as follows, which came from dyndns website - probably don't need everything in it, but I'm not sure what I need...
## ddclient configuration file
daemon=600
# check every 600 seconds
syslog=yes
# log update msgs to syslog
[email protected] # Mail failed updates to user
pid=/var/run/ddclient.pid
# record PID in file.
## Detect IP with our CheckIP server
use=web, web=checkip.dyndns.com/, web-skip='IP Address'
## DynDNS username and password here
login=(purposefully left blank for this post)
password=(purposefully left blank for this post)
## Default options
protocol=dyndns2
server=members.dyndns.org
## Dynamic DNS hosts
Thanks for the help!
  • eton wrote:
    Have you tried to install the apt-get version of ddclient?
    Nope. I used the ddclient-version from the Apps-section of my RN102. It's labeled as Version 1.0.0 by Poussin. Installing anything else would require me to enable ssh-root access, thus voiding any warranty, right?
    http://www.readynas.com/index.php?s=root+ssh
    Please keep in mind that NETGEAR may deny support if you’ve enabled root access.
    viewtopic.php?p=111042#p111042
    By the way, installing the SSH add-on does not automatically void all of your tech support.
    I actually think ssh-access is a must. Some things are just not possible to do via Frontview.
    Poussin have not been that active here during last years. WhoCares is now the main add-on developer. RN102 uses an Arm CPU, right?
    Not that many add-ons here: viewforum.php?f=158
    WhoCares site: https://rnxtras.com/addons/category/readynas-os6-arm
    But I can't find a ddclient add-on for OS 5 or 6 Arm.
    If I where you I would enable ssh-access and install the apt-get add-on and then:
    apt-get install ddclinet
ProSupport for Business
