norbolt
Mar 27, 2013Aspirant
Debian Squeeze/Wheezy on Ultra 2?
Is there a way to get rid of all the netgear stuff and just install vanilla Debian on the Ultra 2?
I connected a serial adapter and I'm able to fiddle with the BIOS and select a USB stick as the startup device. However, when I save and exit the settings, they revert back to booting from the internal USB thing. My USB stick contains the Wheezy netinstall, which I want to run on the box.
- norboltAspirantThat's weird. Debian Wheezy found it instantly. Which kernel?
- mfe_TutorI suppose this can also be done with the ReadyNAS Duo?
I found this:
http://debugmo.de/2007/07/running-own-c ... -readynas/
viewtopic.php?f=7&t=68660 - cabeloAspirantHi Norbolt,
does the wheezy installer find it for you?
I've tried both ubuntu 12.04.2 (kernel 3.5) and wheezy and both installer failled.
after installing ubuntu with sky2 driver network doesn't work, I get no lights on the card and dmesg says something like "link not ready".
reverting to raidator fix the prob so I assume it's not the HW.
any help is appreciated.
thanks - norboltAspirantThe Wheezy installer found both network ports in my Ultra 2 without any hassle, and asked which one to use during install, as expected.
It's been running smoothly 24/7 since the install. - cabeloAspirantyeap, the installer finds both ports (ubuntu and debian) but when I try to configure it with dhcp it fails :(
- norboltAspirantAll I can say is that it worked for me...
Perhaps try sniffing the traffic with Wireshark or similar?
See if it's actually sending something?
Or check the logs on your DHCP server, if available. - norboltAspirantLet me know if you want a list of my loaded modules or something. Though if you own an Ultra 2, the Wheezy installer *should* work for you too...
- mangroveApprenticeA step-by-step of this procedure would be pretty nice... :-)
Can the devices be restored by RAIDAR even if the USB partition is overwritten? - mdgm-ntgrNETGEAR Employee RetiredIf you wipe the Internal flash you would need to make use of USB Boot Recovery to restore it but the EEPROM data would be lost. Without the EEPROM data RAIDiator x86 4.2.x won't work.
- norboltAspirant
mangrove wrote: A step-by-step of this procedure would be pretty nice... :-)
1. connect serial cable - verify that you can access the bios and similar over it
2. make an netinstall x86 debian usb stick - verify that it can boot another x86 machine
3. with serial cable connected and usb stick inserted, boot the ultra 2 with the backup-button on the unit held down to boot from usb. repeatedly hit the escape key on your keyboard while doing this to get the "boot:" prompt
4. type in "install video=off console=ttyS0,9600n8" (no quotes) and run through the installer as usual
5. profit
