norbolt
Mar 27, 2013Aspirant
Debian Squeeze/Wheezy on Ultra 2?
Is there a way to get rid of all the netgear stuff and just install vanilla Debian on the Ultra 2?
I connected a serial adapter and I'm able to fiddle with the BIOS and select a USB stick as the startup device. However, when I save and exit the settings, they revert back to booting from the internal USB thing. My USB stick contains the Wheezy netinstall, which I want to run on the box.
- mangroveApprentice
norbolt wrote: 5. profit
And then, justgrub-install /dev/sdc
Why aren't more people doing this? :?: - mangroveApprentice
mdgm wrote: If you wipe the Internal flash you would need to make use of USB Boot Recovery to restore it but the EEPROM data would be lost. Without the EEPROM data RAIDiator x86 4.2.x won't work.
Thanks. 6.x works though? - mdgm-ntgrNETGEAR Employee RetiredYes. 6.x works, I think.
- norboltAspirant
GRUB on the USB stick? Or what? - mangroveApprentice
Yes, running "real" systems on them. It looks easier than I thought it would be. - fflashAspirantHello,
I have a problem to load the installer once reaching "boot:". When I enter "install video=off console=ttyS0,9600n8" I have the error "Undefined video mode number: 314". I tried to remove the video=off, but same error occured.
When happening, it proposes me to display available mode. I tried the first one "0" and then the following error happened:[ 1.045676] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
[ 1.049523] Pid: 1, comm: swapper Not tainted 3.9-1-486 #1 Debian 3.9.8-1
[ 1.049523] Call Trace:
[ 1.049523] [<c12b1573>] ? panic+0x6c/0x152
[ 1.049523] [<c1429d17>] ? mount_block_root+0x1e8/0x20a
[ 1.049523] [<c1002930>] ? do_alignment_check+0x15/0x73
[ 1.049523] [<c1429d77>] ? mount_root+0x3e/0x52
[ 1.049523] [<c1429e99>] ? prepare_namespace+0x10e/0x13e
[ 1.049523] [<c1429a88>] ? kernel_init_freeable+0x160/0x168
[ 1.049523] [<c12ae520>] ? kernel_init+0x5/0xb0
[ 1.049523] [<c12b8abb>] ? ret_from_kernel_thread+0x1b/0x30
[ 1.049523] [<c12ae51b>] ? rest_init+0x4f/0x4f
I also tried: linux text console=ttyS0,9600,n8 but same error occured.
I have a ReadyNas ultra2, I prepared my debian installer USB key under MacOs by doing the following:
sudo gunzip -c boot.img.gz > /dev/disk2
Then I copied the iso file debian-7.1.0-i386-netinst.iso to the usb key.
Thanks for your help. - fflashAspirantI was wondering if the netgear X-RAID installation could lead to the problem ? The previous error seems to come from missing modules/fonctionality of the kernel.
Does someone have an idea about that ? - repvikAspirant
Because it's hard to find a step-by-step guide? :-P
I've been searching all over the place trying to find some good instructions, but have yet to find any. - repvikAspirant
mangrove wrote: norbolt wrote: 5. profit
I just tried doing this, and now I can no longer boot my Ultra 4. Grub is apparently installed on the usb stick, but it cannot find its files so it ends up in recovery mode (grub+kernels are stored on an ext2fs on the SMI stick).
It'd probably be a somewhat easy thing to fix - if USB booting still worked. But now, holding "backup" no longer boots external USB, not even if I remove all the drives.
Edit: I'm a moron, sorry. I wrote grub on the wrong usb stick somehow. - mangroveApprenticeSo now it works? :-)
