ejcmdq
Nov 09, 2019Tutor
Display port ReadyNas 2304
Sirs, good afternoon Does anyone managed to make the Display Port of ReadyNas 2304 work ? The model is: NETGEAR ReadyNAS 2304, Rackmount 1U 4-bay, Dual Gigabit Ethernet, Diskless (RR230400) # D...
- Nov 15, 2019
It's a standard Mini DisplayPort - something like this should work fine: https://www.amazon.com/DisplayPort-Adapter-Compatible-Microsoft-Projector/dp/B07JDWR6W9
Note I just picked the first adapter that showed in Google Search - there are lots of other choices here.
Marc_V
Nov 10, 2019NETGEAR Employee Retired
@ejcmdg
Welcome to the Community!
The DsiplayPort can be used to display Bootup sequence and HWM. It can be used together with adapters for different monitors.
HTH
Regards
ejcmdq
Nov 14, 2019Tutor
Mark, good afternoon
Thanks for reply !
Can you tell me the specification of port, so I can find an adapter to HDMI or VGA?
Tks, E!
- StephenBNov 15, 2019Guru - Experienced User
- ejcmdqNov 15, 2019TutorNoted thanks Stephen !!
