ejcmdq
Nov 09, 2019Tutor
Display port ReadyNas 2304
Sirs, good afternoon Does anyone managed to make the Display Port of ReadyNas 2304 work ? The model is: NETGEAR ReadyNAS 2304, Rackmount 1U 4-bay, Dual Gigabit Ethernet, Diskless (RR230400) # D...
- Nov 15, 2019
It's a standard Mini DisplayPort - something like this should work fine: https://www.amazon.com/DisplayPort-Adapter-Compatible-Microsoft-Projector/dp/B07JDWR6W9
Note I just picked the first adapter that showed in Google Search - there are lots of other choices here.
ejcmdq
Nov 14, 2019Tutor
Mark, good afternoon
Thanks for reply !
Can you tell me the specification of port, so I can find an adapter to HDMI or VGA?
Tks, E!
Nov 15, 2019Guru - Experienced User
