ejcmdq
Nov 09, 2019Tutor
Display port ReadyNas 2304
Sirs, good afternoon Does anyone managed to make the Display Port of ReadyNas 2304 work ? The model is: NETGEAR ReadyNAS 2304, Rackmount 1U 4-bay, Dual Gigabit Ethernet, Diskless (RR230400) # D...
- Nov 15, 2019
It's a standard Mini DisplayPort - something like this should work fine: https://www.amazon.com/DisplayPort-Adapter-Compatible-Microsoft-Projector/dp/B07JDWR6W9
Note I just picked the first adapter that showed in Google Search - there are lots of other choices here.
Marc_V
Nov 10, 2019NETGEAR Employee Retired
@ejcmdg
Welcome to the Community!
The DsiplayPort can be used to display Bootup sequence and HWM. It can be used together with adapters for different monitors.
HTH
Regards
Sandshark
Nov 15, 2019Sensei
Maybe it's because they're converted legacy devices, but I don't see a thing in the boot-up sequence after the chroot takes place on my systems' VGA . I do get a console when boot is compete and can log in if SSH is enabled.
