fhqwhgads
May 18, 2018Aspirant
Docker CLI Addon for ReadyNAS 6.9.3 - Installation Failure
Hi guys, completely new here. I've just purchased a Netgear ReadyNAS 214 and just setting it up now. I'd like to install Docker on it and from what I've learned so far, Mhynlo has put in a bit of wo...
OOM-9
May 21, 2018NETGEAR Expert
I suspect there might have been another app that you encountered some issues.
There are two things we could do: 1) you can provide remote access with the Secure Diagnostics Mode and PM me the 5 digit code 2) if you didn't want to provide remote access, you can provide the logs to the moderator email and we can see what is causing the issue.
Details for both remote access and logs are in my signature.
- fhqwhgadsMay 25, 2018Aspirant
Thanks! I'll reach out to you later this evening. It's puzzling - This NAS unit is pretty much vanilla (only applied an OS update) and I haven't tried to install anything else besides Docker.
- fhqwhgadsMay 26, 2018Aspirant
Looks like I overlooked the fact that readynas-docker-cli is x86 only. I have a RN214 which is ARM-based ...
- MrGamerChoiSep 21, 2018Tutor
Has anyone successfully installed docker on their arm based device ? I'm aiming to install rtorrent on my device via docker since rtorrent broke my admin web page once so I wanna do it in a docker container to be safe.
Currently I'm having a Readynas 102 (6.9.4) which has an Armv7l cpu running armhf (?). I tried installing docker on my system through ssh but didnt succeed. It said I might held broken packages or something... I think it's because it has conflict with default system packages which pulled from netgear's source.
Here is my step which I followed:
1) Go check https://get.docker.com/ (It shows docker supports armv7l-debian-jessie)
SUPPORT_MAP="
"2) Then I followed the official guide on docker's website: https://docs.docker.com/install/linux/docker-ce/debian/
3) When I performed
apt-get install docker-ce
It said
Unable to correct problems, you have held broken packages
